Just looked at the other DRL, nvm my comment about it separating a little, looks like that is normal. So these haven't separated at all from baking.
Thanks for the tip. Is that still a safe number to bake at if it just so happens that it's not permaseal? or should I just try it how Dan mentioned and if that doesn't work then try again a separate time at 285?Dreaded permaseal
Heres a thread when i tried my first set, my factory 2012's headlights. http://www.355nation.net/forum/exterior/61355-newer-headlights-fogs-permasealed.html
Try 285ish for 15 mins, i hear thats the new magic number for permaseal. you'll also need to remove every bit of it and replace it with butyl. Goodluck
baked a couple set's of depo's at 285, resealed them all (with new and old butyl) i never had a issue. Never tried eagle eyes or tyc's yet. If you'r cautious and let the oven heat up properly, dont let it touch any metal, keep your eye on it etc etc you shouldnt have a issue.Thanks for the tip. Is that still a safe number to bake at if it just so happens that it's not permaseal? or should I just try it how Dan mentioned and if that doesn't work then try again a separate time at 285?
