...and WRT the reference for the "Programming/RPO Configuration..."
BODY CONTROL MODULE (BCM) PROGRAMMING/RPO CONFIGURATION
INTRODUCTION
The procedures below are designed to set-up the body control module (BCM) correctly during
BCM related service. Before you start, read these procedures carefully and completely.
IMPORTANT : The following procedures must be followed:
- Programming the BCM
- Learning the restraints ID
- Programming Theft Deterrent System Components
- Program Key Fobs
PROGRAMMING THE BCM
IMPORTANT : After the procedure is completed, the personalization settings of the
BCM are set to a default setting. Inform the customer that the personalization must be set again.
Perform
BCM special function "Request BCM Info. for SPS", then follow the instructions on the screen. Refer to Service Programming System (SPS) in Programming and Setup for more information.
LEARNING THE RESTRAINTS ID
Perform
BCM special function "Setup SDM Serial Number in BCM", then follow the instructions on the screen.
PROGRAMMING THEFT DETERRENT SYSTEM COMPONENTS
Perform
BCM special function "Request VTD Info. for SPS", then follow the instructions on the screen. Refer to Programming Theft Deterrent System Components in Theft Deterrent.
PROGRAM KEY FOBS
Refer to Transmitter Programming in Keyless Entry for the proper procedure.
IMPORTANT : After programming, perform the following to avoid future misdiagnosis:
- Turn the ignition OFF for 10 seconds .
- Connect the scan tool to the data link connector.
- Turn the ignition ON, with the engine OFF.
- Use the scan tool in order to retrieve history DTCs from all modules.
- Clear all history DTCs.
