How many people have used these in conjunction with each other? It wouldn't drop it anymore I'm assuming? Just ride better?
whats the drop in the rear?Same setup, 2in coils and 2in balljoints on stock tires.
I rode on the bumpstops and had to pound out my wheel wells for clearance. Rode bad because I was on bumpstops but I didn't care, it looked good. If you pull those bumpstops out you'll rub all the time.
Same set up on stock Extreme's, same result.
Did you have to notch your frame?Belltech 3in drop leafs and 1in block.
why would running the ball joints with out springs be bad? Should it not ride just like stock, just 2" lower?Running the drop ball joints without springs is bad.
Running springs without ball joints is also bad.
By all means run them in conjunction with each other.
