http://www.brokentap.com/easy-outs.htmlnope you can get it out with a easy out. Im on my phone now but when im at home i can send u more info on getting it out
Yup thats it. You can get them from sears.
Hmm if it broke before you got it in there all the way then you should try to get it out with the easy out, but you might have cross threaded it. So best thing to do before putting the new bolt in is trying to rethread it with a tap and die set using the one for the bolt size. So if it was cross threaded hopefully it will correct itself.thats the thing, it broke off before it was even in there all the way
thanks for the info, ill have to get one of those kits, i also have to get a new bolt for it too
