Alright, this will be the official discussion thread for this topic
* The rotors on the 09+ models are
said to be 1" larger in diameter.
* Other known facts are that both 04-08 and 09+ models have twin piston calipers and 4 channel ABS.
* The V8 models/09+ ? also have yaw control.
So topics or issues that are needing to be looked into/researched are
* Spindle/knuckles- are they the same?
* Are the hubs the same?
* Are the Calipers on the 04-08 and 09+ models the same?
* Are the ABS wheelspeed sensor differant bc of the Yaw control?
2009+ Front Diagram
2004-08 front Diagram
So I guess we need to research some part numbers or find 09+ model to look at and compare. Open for information and discussion! Please include part numbers/vendor and price if you find them in your post. I will try to centralize the information in this first post
NEW Information!
Brakenit - The '09 rotors are only $48 each / GMPartsDirect.com
1BADI5- Part Numbers
2009+- GMPartsDirect.com
Caliper- 21998527(RT)/ 21998526(LF) $76.23/$76.45
Caliper Support?- 25832166(RT)/ 25832171(RT) $76.45/$39.10
Steering Knuckle- 19208804(RT)/ 19208805(LF) $71.96/$71.96
Hub- 25832143 (universal R/L) $134.65
ABS Sensor- 25832173 (universal R/L) $39.10
Rotor-25832146 (universal R/L) $48.31
2004-08 -GMPartsDirect.com
Caliper-89040312(RT)/ 890404311(LF) $144.80/$134.35
Caliper Support-
Steering Knuckle- 15184895(RT)/ 15184896(LF) $74.19/$75.49
Hub- 25832144(universal R/L) $175.16
ABS Sensor- 15177000(RT)/ 15176999(LF) $35.82/$60.82
Rotor- 89040374 (universal R/L) $68.63
New Update as of 21 SEP 2012
We know this all works now, but I got some information on hardware from the dealer yesterday.
The bolts that hold the caliper bracket in are longer then the 04-08 bolts. You can buy them from GM or pick them up at your local hardware store (
M14 x 2.0 x 36), you'll need 2 for each side, so 4 total. Make sure they are either Grade 8 or higher.
The Copper crush washers for the brake line, well same as above, get them from GM or pick them up at your local hardware store (
10.3 x 14.5 x 1.61). You'll need 2 for each side as well, total of 4.
