1 - 7 of 7 Posts
2006 Colorado 4x4 z85 WT on 33x12.50
So I put a new front passenger wheel hub on, I made the mistake of disconnecting my caliper, and after I bled the brakes they were fine. About 12hes later they’re very spongy and I can’t figure out why. I also haven’t connected the abs cable yet
Make sure that you replaced the TWO copper washers if you disconnected the line at the caliper . Did the master cylinder become empty while the caliper was disconnected ? Check for any obvious leak and bleed again .
Discussion Starter #4
I didn’t even see the washers, thank you I’m gonna Check later.
Discussion Starter #6
So it turns out I blew a rear wheel cylinder. Not sure how but I’m replacing it today. Hope y’all had a good thanksgiving and thanks for the replies
1 - 7 of 7 Posts
