So, as many people may know, my truck has 10 winters on it, and 227,000+ miles.
Lots of rusted stuff underneath I'm dealing with, or just replacing outright. Frame members and body panels are all in good shape, but a arms and leafs are shot, along with some other stuff. Since lifting will put more stress on those parts (and some need bushings etc) I decided to replace them.
I want to make sure I have everything I need.
I ordered:
Rancho 4" lift with RS5000 shocks
2 -1600lb spring rate leaf packs for our trucks by General Spring (5 leaf, 52"x2.5" pack, 2" thick)
4 - 5/8"x8"x3-1/4" round U Bolts, nuts & washers
2 - New OEM Leaf Spring Plates to drill from 9/16" to 5/8" for upgraded U Bolts
2 -New OEM Sized Rear Shackles by General Spring w/hardware (not sure how much lift the springs will give, if any)
2 - new 76mm Z71 rear bump stops (old ones dryrotted/rusted away)
2 - new front jounce bumper/bump stops (old ones dryrotting but still there)
1 - Mayhem Metal Works steering rack mount upgrade kit w/bushings
I plan to order
2 - V8 Torsion Bars
2 - New OEM Z71 Lower A Arms w/balljoints
2 - New Torsion Keys, Cam Bolts & Nuts
2 - Adjustable Lift Shackles (once I install the leaf packs at OEM height to see what I really need)
2 - New Upper A Arms (Slick & Dirty's is the plan at the moment)
Moog Inner & Outer Tierod Ends
Moog poly LCA bushings
Energy Suspension 1-1/16 Swaybar bushings
The Questions:
What am I missing/do I need to order/should I order in addition to the above? I like go big or go home, and do it once, do it right. Should I replace the caster/camber kits since they are cheap and coming off anyway?
For those that have installed this lift themselves, what parts on the truck now that get re-used (other than bump stops, got that covered) do I need to look at replacing before the lift goes on, or during the lift process that isn't in my above list of parts?
I currently run 31x10.5r15 Duratracs on Soft 8's 15x8 w/4" backspace. Do I need to upgrade to a 16" or 17" rim right away, or will my 15's fit for the time being? (yes, i know they will look small, but I'm still @ 3.73)
If I'm only doing the 4" lift with a minor TB crank to fit 33x11.5's, is making other front end mods to increase front travel worth it? I have no plans to body lift ever, since I carry some pretty heavy stuff in the back of the truck with semi-regularity.
And finally, I have no intent to go higher after this is on. I don't want to SOA or SAS nor do I want to notch my frame for my driveshaft. I just want some xtra clearance for offroading, but I'm not as hardcore as some here about it.
Thanks!
I ordered:
I plan to order
2 - V8 Torsion Bars
The Questions:
Thanks!
