AFR readings should have been part of the install but anyways... Each his own.
A dyno is more than just to feed an ego but anyways... Each his own.
There are probably more shops nearby to you unless you live hours away from civilization but anyways... Each his own.
:ugh:
I guess I was not very specific but I would do both, if you want my opinion. Dyno and street tune for this particular application (S/C)... For various reasons. It is a huge investment, I would respect it as such.
You can street tune? Really? Good to know. hehehehhehehe.
:naughty:
The tune was from W2W. Why would I get afr readings from the installer? As for getting afr readings afterwards, see above.
A dyno just tells you the output of the engine when you don't get the tune. Why do I NEED to know that? Enlighten me please.
As for shops that can tune a boosted 355 near me (read as obtain afr ratios on/off dyno, and change to fix if an issue is found)... There were two. Dashworks and ColoradoSportTruck. Dashworks is now defunct (I know this from personal experience with them) and ColoradoSportTruck is not interested in working on the 355 anymore, at all as far as I can tell. I have tried to contact them numerous times without a decent response.
Now I am right in the middle of civilization and have numerous contacts in the performance modification scene in CO (my dad and two of my uncles have drag raced since before I was alive, my uncle even owned a performance modification shop, which I worked in, until it burned down and he left the business and started a new one). I know the performance scene around here and there just isn't any options that I have found for what I am looking for and what you are suggesting.
Now you seem to be knowledgeable on the subject. Would you be willing to fly out here and offer afr readings and a tune? I have doubts but I would be willing to let you try. You and Stocker are the only people I know that can really tune these trucks with positive results. You, from what I understand, have no experience with boosted applications though.
I have reasons for everything I have done and have taken every step to make sure my investment works out. Otherwise thanks for your concern and opinion.:355:
It is easy to say you should have done this and you should have done that from the outside looking in but honestly you have no idea how much time and money I have put into this project. I have even spent hours helping others work on similar projects from what knowledge I have obtained. S/C'ing was the goal from the day I bought my truck and I have spent all of that time (2+yrs) obtaining info, saving, and working on this project.
Justin I did buy from that douchebag xhr. The reason I asked about the #'s are
they are not the same as what RK Sport says when I have talked to them.
I don't know what stocker was bitching about I can't see it run worse with the new injectors. I think he had a wee bit too much boost and just toasted a ring. But we will never know.lol
MD
I think that at one point they tried a different pulley for 6psi but what you have is the 4psi pulley which is what XHR was running when he broke his rear end. Therefore your boost should be at what RK says and is designed for.
If you ask XHR about what happened to Stocker it is because he leaned out the top end trying to counteract some problem they were having. I am not sure I remember the exact reason but XHR was confident that the problem for Stocker was that he had the top end running too lean.
At this point I am trusting W2W's tune until I am SURE someone can offer a better tune. I thought Stocker could with the wide band but he didn't. I move to Houston next summer though and then I will be able to find out for sure what is up because Stocker is supposedly moving back there. Until then or I find a better option I am kind of up in the air about what to do.
I apologize for the essay here but there was a lot to be said.
