Don't know. The Owner's Manual says: GM Power Steering Fluid (GM Part No. 89021184) Sorry that doesn't answer your question. Maybe some of the other guys will drop by later with additional info.
You know years ago we use to use ATF in Power steering. BUT why do it? Use the correct stuff. Who knows what has changed in the last 50 years to power steering components and power steering fluids.
power steering fluid is pretty much ATF without the dye and friction modifiers. it'll work as they're both hydraulic fluids doing hydraulic fluid things but you should use the right stuff if you can. When I did my trans fluid flush at 60k miles, I used the rest of the spare dex 6 to flush the power steering and it works
