There is an excessive amount of build up...I cleaned my throttle body 5000 miles ago and last week I noticed my idle was a little off so I took it off again and to my surprise it was filthy...
This brings me back to my concern about my cat being/starting to be plugged. I still haven't had time to remove it to see if it really is...In my case i think its just excessive back pressure causing it because my truck runs rougher, the idle fluctuates more, and its performance has slowly been decreasing...I called the dealer today and asked if they had any seen any other colorados with plugged cats and he said no...then he told me all those symptoms could be caused by the IAC failing or a bad MAP sensor...I had to stop myself from laughing and just hung up...for the local guys, it was a service advisor at Midway that told me that...
