1 - 2 of 2 Posts
how do you determine if you need to shim the carrier bearing ?
i had to put 4deg pinion shims in to get the right angle on it.
do you measure the front drive shaft the same way with an angle finder ? does anyone know what it should measure ?
1 - 2 of 2 Posts
