Chevrolet Colorado / GMC Canyon License Plate LEDs! Plug & Play Install! See Photos!
Colorado / Canyon License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Colorado / Canyon. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Colorado / Canyon!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Colorado / Canyon looks at night.
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens) HP3: Much brighter than OEM bulbs. These are bright! (56 lumens) HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Colorado / Canyon).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Reviews
"I bought these lights for my back up mirror/map lights and they are great! So far so good, installation was a breeze and they are pretty bright. I've had them in for close to a week now and I love them. Would definitely recommend these to anyone! (Posted on October 10, 2014)" -ColoradoKid
Re: FS: Colorado / Canyon License Plate LEDs! Plug and Play Install! Same-day shippin
If anybody orders the cupholder lighting for the bucket seat console, looks like 72mm is a perfect fit. Also if you order license plate lights, get those smd2's. The hp3's are just a hair too long for the plate lamp housing. Good products, good customer service, quick free shipping for members. :thumbup::mjb::boobies:
Colorado & Canyon Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Chevrolet Colorado & GMC Canyon's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your fog lights a nice bright white that closely matches...
Research Automotive Lighting
At Diode Dynamics, we want our fellow Chevrolet Colorado & GMC Canyon enthusiasts to be educated on automotive lighting products, so that they know they are purchasing the best products for their truck on the market. We have devoted this portion of our website to...
2015 Chevrolet Colorado Switchback LED
At Diode Dynamics, we carry a full line of LED bulbs, including these unique dual-color switchback LEDs! Our HP24 is a brand new design, and the brightest available on the market, designed by our engineering team in St. Louis, Missouri. Your order will...
2015+ Chevrolet Colorado LED Tail Light LEDs
2015+ Chevrolet Colorado Tail Light LEDs
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb compared to factory:
SMD27...
Colorado/Canyon Footwell LED Kit! Multicolor & Single color kits! Control w/Phone!
Looking to add a fresh look to your truck's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your vehicle.
Diode Dynamics has been...
