Chevy Lean
1798 Views 17 Replies 7 Participants Last post by  dustbunny
Whenever I lowered my truck a few months ago (3/4), I trimmed the passenger side spring. It fixed the lean a little but I didn't cut enough to make it level. I really do not want to take that spring off a again because it was a headach. I was wondering if I put a 1.5'' drop block on the passenger rear and a 1 inch on the driver side rear, will that level it out?
Or should I not be lazy and do it the right way, lol.
1 - 18 of 18 Posts
I would do it the right way
There are a couple part numbers in this link for spacers if the op decides not to cut more spring. http://www.355nation.net/forum/chassis/60680-no-more-chevy-lean-80-a.html
I guess I will, lol.
I have 3'' LCA's in the front right now and 1 inch blocks. I am about to order 2 inch blocks. What kind do you guys recommend? Will I need a pinion angel?
I got my 2" from auto zone
How much coil did you cut? I am planning on doing this soon and want to only pull the damn coil out once haha
I think it's only 1 coil
I cut half the coil. I believe 1 coil is 1'' drop
Well you've lost me. You're talking about trimming your coil springs, right? :ugh:
Ninja'd. Disreegard.
I threw 3" LCAs on my truck w/ 3 of the BellTech spacers. Leveled me out side to side, but the rear was lower with the 4" blocks. No coil cutting (kind of a pet peeve of mine). For now, I just keep some pressure in my Monroe air shocks so the rear sits level. This winter I'll probably snag some 3" blocks. (PS: ZQ8 suspension)
I was going to get the spacers also, I would just hate to have to lift one side. Would much rather lower a side.
Trust me, a part of me died the day I installed the spacers...
But IMO that was a better route than cutting the coils. Different strokes...
Ok, I am going to drop the back first. Should I spend the extra money on JTR blocks or will the cheap ones at O'reillys or Autozone work? Since I have belltech 3'' leafs in the rear... will I need shims?
I have the bt 3" leafs and auto zone 2" blocks and bt rear shocks I like em and I'm not running shims
I have read that if you go over 4 inches in the rear, you should buy them. True?
1 - 18 of 18 Posts
