This seems like a popular issue with our trucks, so I will share my experience. As you know, I do all my own work on my truck and I also get to examine other trucks when I use HP Tuners to dial in their trucks. So I get to see a broad range of vehicles from the Extreme dropped 4" to a 8" lifted Z85. All the way down to OEM stock 355's...
Our trucks inherently have a drive line "clunk" or slap to it from the factory. GM calls this normal play in the drive line. It is present on almost every 355 I work on and can even be found on full size trucks...
With that said, I ran into a problem past the normal noise (clunk/slap). Out of the blue, on hard acceleration (WOT), I got a "clicking" noise from the rear of the truck... At first it almost sounded like my locker was on its way out...What I found was my U-joints completely smoked. $26 bucks later and an hour of my time, problem solved. I used after market u-joints (Precision) because of time constraints and location (I would have preferred to use OEM HD ones)... The Precision ones are grease able, if that matters to you.. If you go to the dealer, I believe you will have the option for AC Delco and OEM. OEM being a heavy duty u-joint but non grease able (sealed).
U-joint to transfer case:
