1 - 5 of 5 Posts
Alright, so far I have soldered in LEDs in the 4x4 circuit board and the head light switch circuit board with no problem using 5mm LEDs and resisters on the positive lead.
When I went to do the climate control, I check what is positive and negative, soldered on my LEDs, and checked to see if they were lighting up in the truck. At this point two were not working, so I resoldered them. Tested again and 3 sent working. Tried to resolder again and now one of the contacts on the board won't accept solder, I can't get the led soldered on.
So I gave up for the night, put it all together and back in the truck and now I don't have any LEDs on the climate control working!
Has anyone had this? What could my problem be? Do I need a new climate control board or can I fix it?
Everything else works on the board, just no lights.
I had this exact same problem, it happened the first time I ever did an LED install on my climate controls. The boards on the climate control are pretty cheap. After heating up and cooling down those solder points on the board a couple times, eventually they fall off and no matter what you do you won't be able to make a connection. It happened to me, so my solution was to run small gauged wire from the large negative and positive pins to all the negative and positive locations. Just take a multi-meter and find the ground pin and find the pin that has positive 12v when you turn your headlights on. It's a lot more work, but it will solve your problem. Ever since then I've learned to be extra sensitive when it comes to working on those circuit boards.
Youre welcome! Same size wire that I used. Mine's lasted almost a year now with zero problems.
1 - 5 of 5 Posts
