1 - 3 of 3 Posts
In my 2005 Colorado i have this problem where when i start the truck for the first time at night the cluster light works, but if i run into the store and shut the truck off, when i come back the cluster light does not work anymore. all other lights in the truck work great. i was wondering if it was just the cluster itself but i am worried its something that has to do with wiring.
Thanks!
Thanks!
If you want to try a replacement cluster, I have 2 of them, one is from a 2007 and the other is from a 2005. I would sell either one cheap and you could use it to test if the problem is in the cluster....
The problem is likely the dimmer switch next to the headlight switch. They can be cleaned easily.
This thread will show you how to take it apart:
you'll want to clean the wipers, bend the tabs to make sure theyre making good contact, and reapply a small amount of dielectric grease.
1 - 3 of 3 Posts
