1 - 3 of 3 Posts
Anybody got the service manual? Want to scan and post the pages?
Thanks!
find a shop with "all data" its a shop repair program that has all of that info. we have it at our shop. i will look to see what i can find.
Clutch Assembly Replacement
Tools Required
J 36660-A Torque Angle Meter
Removal Procedure
1. Remove the transmission. Refer to Transmission Replacement in Manual Transmission - Aisin AR5.
Object Number: 1302140 Size: SH
Click here for detailed picture of above image.
2. Remove the clutch pressure plate bolts (1).
3. Discard the bolts. Remove the clutch pressure plate (2) and driven disc (3) from the dowel pins (4) on the flywheel (5).
Installation Procedure
1. Install the clutch pressure plate (2) and driven plate (3) to the dowel pins (4) on the flywheel (5).
2. Install the clutch pressure plate bolts (1) finger tight.
3. Use the Snap-On A145 Clutch Aligner Set, or equivalent, to align the clutch driven plate (3) to the clutch pilot bearing.
Notice
Refer to Fastener Notice in Cautions and Notices.
Object Number: 71490 Size: SH
4. Tighten the NEW clutch pressure plate bolts in the sequence shown.
Tighten
1. Tighten the clutch pressure plate bolts in sequence to 20 N·m (15 lb ft).
2. Use the J 36660-A in order to tighten the clutch pressure plate bolts in sequence an additional 45 degrees.
5. Install the transmission. Refer to Transmission Replacement in Manual Transmission - Aisin AR5.
1 - 3 of 3 Posts
