1 - 15 of 15 Posts
Recently lifted my I4 to accommodate 33"s, truck has 100k on the original clutch, and it is an absolute dog. The 3.73s don't help either, but just curious how many people have swapped the clutch? I pretty sure that's the only thing out of all the vehicles I've owned that I've never had to replace, so I'm sure there's gonna be headaches along the way, any advice would be greatly appreciated, or recommendations on which clutch... Thanks!!
I'm not sure I understand your reason for a new clutch.
Do you want a new clutch to increase performance, or a new clutch to replace yous that is worn out?
You didn't actually indicate that your clutch is worn out.....
Factory Fresh
For me it was harder to bleed the slave cylinder then it was to pull the trans. There is more then enough to get to all the bolts and the trans doesnt weigh alot either. I would recommend getting the disconnect tool for the slave line its maybe 10 bucks and i bought it from napa.
you dont need a tool for the slave line theres a clip factory installed you just push it and it comes loose.. also the hardest part of the entire swap will be to get the little pilot bearing to come out of its little home and to align the input shaft into the little a hole of the pilot bearing i hope you have a trans jack cause using two floor jacks alone is not very fun!... thats the hardest part along with what others have said about bleeding the master cylinder/slave it takes some time.
What are the benefits of this? just wondering for future reference.
The h3 clutch is slightly larger than the stock 3.5 clutch... 11" vs 10.5" which provides more clamping surface I guess.
1 - 15 of 15 Posts
