1 - 20 of 22 Posts
hey so Im new to this site and to owning a Colorado so i need a little help with my truck... so i have a 2004 Chevy Colorado LS 2wd and i don't want to spend alot of money on a lift because Im also focusing on buys some new tires also and im kinda broke haha.
so it doesn't have torsion bars so i cant use the keys but i saw you can use spacers...
so what are you guys opinion of what brand to use?? and how big of a spacers could i go like 2.5??
I also saw a thread that said i could use one for a 96-04 Tacoma is that true or im i just totally wrong ahah.
any input is appreciated thanks!!!!
There are cheap 1 or 2 inch spacers on ebay.
Or suspension Maxx makes a kit for 2 to 2.5 inch
Readylift makes a 2.25 inch spacer kit
I'm gonna have my suspension max spacers for sale hopefully after i get these coilovers installed tmw
Just cause they are less than 2" thick does not mean you don't get two inches. It also changes angles on the struts and arms and that with the thickness give you the 2-2.5" of lift. It's just like how a shackle that is 2" longer does not equal 2" of lift. You have to factor in the fact that these things sit at a angle and are not perfectly vertical. You have to think about it in more than one dimension
And yes go SMaxx. They are easy to install and lots of us use them so you know you can trust the quality of them.
Yeah that lol
2" lift shackle will give you two inches but they are actually more than 2" longer if you measure with a tape measure.
Ok. I figured that the angle and ball joint relocation would give me the rest of the lift. Thanks. So will 2" shackles give me less or more than 2" of lift?
Unless there is something special about a 2wd, ball joint modifications won't lift your truck....have you heard otherwise (for fact?). It's not something I am familiar with. I know it does not lift the 4x4 trucks, which use essentially the same ball joint mount design-I think.
Probably confusing the balljoint flip, which iirc, is meant to relieve the binding on the balljoints not increase lift
1 - 20 of 22 Posts
