1 - 14 of 14 Posts
My truck was hit by lightning 2 years ago. Had it at the dealership for over a month and said it was fixed. All the electrical was wiped out. Now my truck will not start on occasions. The lights, radio, ect.. work so I know it not a battery issue. There is no noise when I try to start it. I do get an error message on the dash:traction, brake, and ABS fault. I have had it to several mechanics and they can't find anything wrong. Please help!!! I appreciate any advise!!!
Discussion Starter · #5 ·
Any new work or modifications to the truck lately? Seems suspicious that the work performed 2 years ago is all of a sudden creating today's problems.
It began to not start shortly after the dealership said they fixed it. Brought it back to them several times and they found no problems. It will not start in about 1 out of 15 tries. Eventually it will start
up.
I work for a forklift OEM, basically the same as an automobile. The hardest gremlins to solve are those created by a lightning strike.
Yes 08Canyon; things can go wrong days, weeks, months, and years later after a strike. For instance; solder may slightly brake but still have a connection, a few bumps later it fails.
DEP
...The hardest gremlins to solve are those created by a lightning strike.
DEP
Yep.
Unless the entire electrical system is replaced, there's no way to be sure, ever.
OP, you need someone to do a step-by-step troubleshooting job on this.
As in, starting with a mutimeter at the starter... is it getting a start signal there?
If not then is the PCM outputing the start signal?
If not then why? If yes then where is it getting lost between the PCM output and the starter? Is the start relay being actuated?
... and so forth.
You may need someone other than a dealer service department.
They'll probably just swap parts until something happens.
If the truck doesn't start and you have a flashing (or steady, can't remember) padlock icon, then it's Passlock preventing the vehicle from starting.
How d'ya like them apples
1 - 14 of 14 Posts
