1 - 9 of 9 Posts
do you have a brake light out? definately check the fuses and have you had the recall done for the brake lights?
just checked the fuse for the cruise control, still good.
my brake lights are still working...
I did just add my new modded led third brake light, but it's working. I haven't used cruise control for a couple days...I just noticed it was out yesterday.
Thats probably it. I dont know how to fix it though.
off topic but where did you come from todd, converted huh? good to see you around here.
Not converted. I just came to the conclusion that eventually other sites devoted to this truck will pop up and that I might as well help and learn where ever I can. :)
sometimes the use of an LED bulb or other LED modification will cause the BCM to malfunction. the LED's dont draw nearly as much current as a standard automotive type bulb, and this confuses the BCM. you may have to add a resistor or "load equalizer" as some people may call it, to correct the problem.
1 - 9 of 9 Posts
