I guess it's my turn to chime in. 2010 3.7l. 230k on the clock. Bad valve guide seals plus #3 & #4 valves not seating properly. Number #2 intake cam cap overheated. Scarred cam journals. So, it was time to refresh the head. Since my local shop doesn't line bore, I ordered a reman head. In this time I am also going through every other thing I can think of. So, I found a 2 row all aluminum radiator to keep thing cool (since the oe is obviously not up to the task). New harmonic balancer, new thermostat, new starter, new fi wire harness, ign coils, spark plugs, cam actuator, cam actuator solenoid, cam pos sensor, timing set w/ balancer shaft set. And since I had to take the rack and pinion out, new inner and outer tie rods plus ball joints and sway bar links. Amazon loves me right about now. This is all thanks to the endless research I have done through this site. If my truck will be down, it will only be down once! What I will say is the improved design on the head bolts....if you follow the crack, tap procedure come out just fine. I thankfully did not break a single head bolt.
PROST!
