21 - 28 of 28 Posts
Re: Dana 44 Rear Axle Swap
Part#16150 Yukon gear. I couldnt find any part# for the Spicer. If I did I wasn't confident it was correct. So I just went with AutoZone special order, I figured if it didn't work I could return it with no hassle. Yukon is a good quality brand, should hold up well.
· Hybrid
I don't really post much in the Forums anymore, but I felt the need to express my appreciation to you for all of the valuable information provided in this thread. Although you weren't the "first" person to spend the dollar signs on this idea (Jeep guys have been doing this swap for years :roll: ) you are however, the only person to document a clear and concise list of part numbers that made this swap almost effortless for me. I've read through some of the other *look at how cool I am* threads, but got very little out of it. So again, I thank you Mr. Smith for taking the time in developing this contribution for "the cause".
I'll add a couple tidbits for what it's worth...
The hard brake lines from '99 Honda Passport I salvaged are compatible with the existing proportioning block, and the calipers do clear a 15" wheel.
Discussion Starter · #25 ·
Glad you found it useful and thanks for the additional info! Next time I update the parts list and first post I'll be sure to add it in so folks don't have to look too hard for it.
-Sam
Ok 2 questions.
1. what did you do to change the pinion yoke flange.
2. did you use the stock driveshaft? are you lifted, stock height?
Discussion Starter · #27 ·
1. What did you do to change the pinion yoke flange.
I used a D60 1330 Yoke, seal, and a crush sleeve eliminator that I had made - part numbers are in the first post. You could always stick with the crush sleeve, but I won't reuse them and I think they're a pain in the ass to setup. Keep in mind I used the later D44HD which has a bigger ring gear and pinion.
2. Did you use the stock driveshaft? are you lifted, stock height?
Stock driveshaft with a 1330 U-Joint. Truck was (it was totaled a while back) stock height.
-Sam
2011 chevy Colorado 2.9L AT Posi
For this project I will be swapping out the stock AAM 800 (G80, 3.73 gears) in favor of a Dana 226 (Model Super 44) with disc brakes, 4.30 gears, and TRAC-LOC from 2001 Honda Passport. Before getting into the actual build, here’s a little background tech. Isuzu Danas can be found in three widths:
  • 1993-1995, Model 44/216, RODEO, 58-inches wms
  • 1996-1997, Model 44/216, RODEO, 61-inches wms
  • 1998-2002, Model Super 44/226, RODEO,PASSPORT (HONDA), 63-inches wms
All are a semi-floating design and use 30 spline axles. Contrary to what you may have heard, they do not use c-clips. Disc brakes, TRAC-LOC carriers, and either 4.10 or 4.30 gears will typically be found in assemblies that come out of V6/4WD models. Pre 98 will all have 8.5-inch (216mm) ring gears while ’98+ Isuzu Danas will have 8.9” (226mm) ring gears, 30 spline axles, and D60 size (29 spline) pinions shafts. Super 44s are significantly stronger than the older Model 44s. Dana does not provide maximum momentary output torque capacity for the Isuzu 226, but a conservative guess would be in the neighborhood of 4000 lb/ft; I’ve seen estimates upward of 5000 lb/ft. (For what it’s worth, a low pinion rear 8.9 inch Super 44 with 32 spline axles is rated for 5340 lb/ft).
So, back to my project. Why did I choose to go with a 98+ Isuzu Dana 226? Here’s the list:
  • Width. The 98+ Isuzu Dana is a centered diff that measures 63-inches wms compared to 63.5-inches wms for the Z71 AAM 800.
  • 6 on 5.5 lug pattern. As a bonus the hub measures 101mm just like the 355s and H3s.
  • Price. I wanted 4.30 gears, a clutch pack LSD, and disc brakes in that order. I got a clean, low mileage assembly for $250. We’ll have to see what the final bill comes to.
  • Strength. I wanted an axle assembly that was at least as strong as the AAM 800, which is rated at a momentary torque output of 3510 lb/ft. GAWR is similar between the two.
  • Options. More locker options are available for the Dana's compared to the AAM 800. More gear options for the 226 if I swap carriers or drill it out to accept 1/2" ring gear bolts.
  • Country of origin. I really like reading “MADE IN USA” on my parts.
Here's an updated list of parts (you must be logged in to see it). Except where noted the numbers are Dana/Spicer. If a part isn't listed then I haven't been able to verify the fit yet. Prices are what I paid less shipping or sales tax. Note - I don't always purchase from the cheapest vendor. If someone takes the time to put in some extra effort or answer questions they get the sale. If you see any typos or errors shoot me a PM and I will re-verify and correct. Links to diagrams and service manuals are in the thread. When I get a chance I'll move them up here. Project photos are in my Picture Album.
hi following ur steps and recommendations i recently installed these type or rear axle on my 2011 colorado 2.9 AT dont know exactly what kinda description fits but it was from a 2001 honda passport v6 4wd has disk brakes 4.10 gears and yes LSD looks like a lit bit stronger than stock gm axle
my question is: how do u handle or solve the abs problem and also the ebrake ???
what do U do? thanx i would gladly appreciate ur answer need to solve this problem
Tire Wheel Automotive tire Automotive lighting Vehicle
Tire Wheel Vehicle Automotive tire Hood
Hood Motor vehicle Automotive tire Blue Automotive fuel system
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Valve Plumbing Gas Auto part Machine
Tire Wheel Automotive tire Motor vehicle Vehicle
Watch Household hardware Clock Font Metal
Automotive tire Gear Automotive lighting Auto part Rim
21 - 28 of 28 Posts
