Got 2 fobs or only 1?
I only have one fob. I definitely would have tried the other fob if I had one.Got 2 fobs or only 1?
Haha... No judgement here... I had to do this on my firebird to get extra range. Sadly, this problem occurs when standing directly outside the drivers side door.Not sure why it works but try this: Next time it won't like , hold the Key Fob next to your cheek bone and push the Lock. I know this will probably generate some response about my intelligence as it sounds stupid to me too, but, try it. My 8 year old grand daughter suggested it and wa la., it worked. For some reason it seems to extend the range.
I do have an aftermarket radio. I used the Axxess LC-GMRC-01 when I installed it. (so no hacking any wiresAny aftermarket radios or alarms? Might disconnect the battery for a bcm reset.
Oh my goodness. I have never heard anybody else ever say this. I've used this practiced for 20 years. I use the bottom of my jaw though.Not sure why it works but try this: Next time it won't like , hold the Key Fob next to your cheek bone and push the Lock. I know this will probably generate some response about my intelligence as it sounds stupid to me too, but, try it. My 8 year old grand daughter suggested it and wa la., it worked. For some reason it seems to extend the range.
I will try this tomorrow when I get to work... hopefully no one sees me crawling out my passenger sideHave you been able to confirm if the dome light is functioning properly? I wonder if the locks are not working becuase the system won't allow it to lock (like security reasons). The point...perhaps the door switch is not working properly.
As a silly suggestion, how about exiting the vehicle through a different door then trying to lock. That removes the driver door from the equation.
The cold weather is always a possibility... I hate living in utah and miss florida terribly. I've had a few problems that I've resigned to cold weather issues.Mine did the same thing intermittently a couple of weeks ago when I was in Maryland, but has worked fine ever since I returned to warm Florida.....possibly something related to temperature?
Thanks for the suggestion... I will add this to the things to try and report back here if I find a solution.Will it do the same thing if you pull the radio fuse?
Hi copekyle,So I think I've hammered down the weirdness of the delayed locking of my doors. As stupid as this sounds, I started parking somewhere else and haven't had the problem in 2 weeks. I think the fact was the I was parking directly in front of the main transformer for our facility and it was messing with my signal. I came to this conclusion because both my cell phone signal and wireless internet signals die in front of that thing too (different frequencies I know but it may just kill all wireless frequencies).
