This might be your problem with this issue I have 06 canyon 4x4 crew cab I been struggling with windows and door locks issues for a year I try everything to fix the problem that everyone else had I was going to change the BCM and I was glad I didn’t until one day I was doing a accessory plug bypass to turn off when you turn the key off and found that the daylight running light fuse was blown replaced that fuse everything started working again it’s been 3 months with no problems Now with the pass security problem I just did the white wire cut bypass and installed a alarm that makes the truck not start if the alarm going off did that bypass 10 years ago with no issues with truck not starting
