Those stops are usually put at a location that is close the the travel limit of your upper balljoint. Either withing the joint itself, or the "cup," for lack of a better term, that the ball joint sits in will bottom out on the knuckle.
I have my truck turned far beyond what is usually "reccommended" and I trimmed the metal stop slightly. It did help some. You could also considering making a travel strap for the front end that would tighten out a 1/4" before hit the metal stop
I also agree with what was stated before. Your travel does not change with a torsion bar lift, you are skewing the travel ratio to more compression, and less rebound. Which often can be good in various offroad conditions. If you have, as easy round numbers, 6" of travel from the factory, it is often set so that 3" of that is compression, and 3" is rebound. If you index the torsion bars for 2" of lift, then you would now have 5" of compression travel and 1" of rebound travel.
