I've had this problem with the driveline clunking when I step on the gas, let off of the gas, and shift into drive and reverse. It only happens occasionally, so I didn't think much about it.
I've also seen threads made by others that have the same problem. Well, I just went over drivelines and the such in class today, and saw an article in my book that pretty much explains it all.
This is directly out of my book, so, if the information seems incomplete or missing some stuff, don't complain to me, direct your complaints to CCi, which ordered the books. >.<
Spline Bind Cure
Driveline "clunk" often occurs in RWD vehicles when shifting between drive and reverse or when accelerating. Often the cause of this noise is excessive clearance between the teeth of the ring and pinion in the differential. Another cause is called spline bind and occurs when the changing rear pinion angle creates a binding in the spline as the rear springs change in height. For example, when a pickup truck stops, the weight transfers toward the front and unloads the rear springs. The front of the differential noses downward and forward as the rear springs unload. When the driver accelerates forward, the rear of the truck squats downward, causing the driveshaft to be pulled rearward when the front of the differential rotates upward. This movement on the spine often causes the spline to bind and make a loud clunk when the bind is finally released. The spline bind is not to be confused with "launch shudder," which is the vibration felt during acceleration when the front and rear driveshaft angles are not equal. Weak rear springs or an overloaded vehicle usually causes launch shudder.
The method recommended by vehicle manufacturers to solve this noise is to follow these steps:
1.) Remove the driveshaft.
2.) Clean the splines on both the driveshaft yoke and the transmission output shaft.
3.) Remove any burrs on the splines with a small metal file (remove all filings).
4.) Apply the manufacturer recommended (often synthetic) grease to the spline teeth of the yoke. Apply grease to each spline, but do not fill the splines.
5.) Reinstall the driveshaft.
I hope this helps anyone who was wondering what caused this, and how to remedy it.
Spline Bind Cure
