1 - 10 of 10 Posts
I plan on replacing my driver side door speaker but I have a trip coming up this weekend and wanted to see if i could fix the stocker for the time being. If i have the balance even I can tell that the sound is 90% passenger if i shift the balance to left i can hear music coming from the driverside but its faint.
Anyone experience this? could it be a pinched wire?
Probably just a blown or defective speaker, unless it's your amp or whatever you're driving it with.
Could be the HU going bad. To eliminate sources, switch the speakers from left to right. If the lack of sound follow the speaker, then it's a speaker. If the same corner stays faint then it's in the stereo.
A pinched electrical wire isn't like a fluid line...pinching it won't allow only a certain amount of current to flow unlike pinched fluid lines.
Another test, sit in the middle of the truck and check for equal sound. I notice an unbalanced sound when in the driving position, sometimes.
Discussion Starter · #4 ·
Well the system is stock. so unless there is a stock amp its being driven from the HU.
I ordered some speakers. 6.75 2ways. Its a WT, looks like only two speakers. If its the HU i ll have a better excuse to replace it.
I am leery when its comes to replacing HU's because i live in buffalo and i dont want to give someone an excuse to break my windows.
Kind of why I haven't swapped the stereo in my truck ... probably 10 years old now face doesn't come off and it only has an aux input.
I have a similar problem, except that , on turns, sometimes the volume comes back for a while, and if I open the driver's side door, I regain full volume until I shut said door.Service advisor at my stealership said the wires for the speaker through the door are stretched after @94k of driving. I can't figure out how to remove the audio unit (stock) face, so I can run a separate set of wires to check this theory out.
Swap speakers from side to side. It will be easier. Plus you don't have to tap into the harness to test it.
To access the HU:
The silver bezel comes off. Working from the bottom, pull it away from the dash. There are clips up each side, 2 per side I think. Maybe 3.
Disconnect the plug from the hazard button, and if it is a 4x4 the selector switch.
Once the HU is exposed remove the 3 small screws, two on one side, 1 on the other. Then pull out, unplug the antenna and harness.
I'm doubtful a 'wire is stretched'.
Again, swapping speakers from side to side is easier. That tests if the speaker is bad.
1 - 10 of 10 Posts
