1 - 3 of 3 Posts
My driver window inst tracking right, when i put the window down the front bottom corner dips in first, then the back goes down, and then it is all pulled down together. Any one have any ideas what it may be. I'm thinking either the motor on that side is going bad or the teeth on that motor aren't grabbing. The only reason i can i because it has caused my tint to peel off in that corner and i want to get it straightened out before i get it re tinted!
edit: also i have managed to pick up some white paint specs from somewhere on my driver side windows and a little on the paint on the doors. Any suggestions in getting the paint of with out any damage.
Also check that the bolts that hold the whole shebang in place are tight.
1 - 3 of 3 Posts
