1 - 6 of 6 Posts
Are the driveshafts from an i4/i5 auto and manual transmission the same length? Obviously assuming the same cab configuration (in my case, reg cab).
Yep I'm pretty sure they are cause the i4 sits back farther. Along with your trans mount is in the same place.
Not sure if this helps but my truck(reg.cab) started life as an auto,then I swapped in the V8 and went to a T56-6sp. And the stock driveshaft fit the stick with no mods and still has the original ujoints with over 100,000 V8 miles! Of course the last time I bragged about my stock rear end I scattered it all over the place!!!
Discussion Starter · #6 ·
Haha, extremels6 that does help too. Thanks guys!
1 - 6 of 6 Posts
