Is the water temp gauge mechanical or electrical? Where will u locate the sending unit? Thanks.Just bought the dual SFAN4500 setup from James. getting ready for the summer heat.
also bought a oil press & water temp 2 5/8" gauge setup from Summit.
TurboAl......r u running the Stant #14077 stat?Freak, have you changed your stat ? with my 170deg stat my water temp runs 178/183
cruising down the Tpk.at 70/75mph
FWIW, I've tried water wetter in 2 vehicles.......ScanGauge showed zero, zip, nada difference in both.Nope, still stock stat. Been thinking of oicking up a bottle of water wetter to add to the system.
