I've owned my truck for 50,000 miles now and in that time, I haven't a single check engine light, abs light, passlock light..... Nothing. Until today anyways. So i'm driving down the road and I lose all of my gauges. Then the radio starts turning on and off. The fourwheel drive selection lights are blinking. All four fan speeds work, but the fan is blowing slower than it normally would. All the wiper speeds work, but the wipers move slowly. Also all the interior lights are dim. The ABS light comes on and off while the passlock light stays on solid.
Things that I have done:
- Checked both ground blocks at each fender well. Cleaned them and tightened them down good.
- Checked the battery voltage while the truck was running and when it was off. 14.2 volts while running and about 12.8 while off.
- I unplugged both battery cables, touched them together and held them together for about fifteen seconds. Then re-installed them, and the same result.
I'm leaning towards a BCM problem. But I want to get some input before I go to the stealership.
:anger::anger::mad2::disgust:
