ok last night i began installin the lowering kit on my truck...i got the arms in without too much problem took 1.5 hours but when i got to the back and tried to put on the 4 inch blocks i had trouble...
i disconnected the shock bolt, then undid the nuts from u bolts and removed the spring plate...now when i went to posistion the angle cut block the nipple wouldnt fit into the hole in the axle...seems to big a little too big for the hole...plus i need to know which way the angle goes on the bloclk (ie the high end of the angle to the rear or front) and then the ubolts didnt seem quite long enough to go through the sprig plate (but i think the block may have been backwards)
anyways if someone could pleas help me i would really appreciate it
HELP!!! lol
HELP!!! lol
