This is what a 211,000 mile radiator looks like. What you are seeing built-up on the radiator is grass and dirt. Blocking air from passing through the radiator. A good 30% of the radiator's surface is blocked and will cause the engine to run hotter and not cool properly. An invisible hazard to your vehicle's cooling system as this is in between the radiator and the AC condenser. If you live in an agricultural area, make sure your radiator's front surface is clean to maintain proper engine operating temps.
Sent from my Samsung Galaxy Nexus using the crappy AutoGuide.com free app
