1 - 20 of 39 Posts
Ok, so I was putting some interior leds in and I got them in and went to start the truck and it wouldn't turn over it would just click. I was using an add a fuse thing to power it wih one of the accesory fuses. I took the whole led kit out, and put a new fuse in.I tried jumping it and that didn't work. I checked every fuse and they were all fine. I wiggled the fuse box wires a bunch to see if something was loose that didn't work. I don't know what to do I didn't know accesory fuses connected to starters and stuff. Please help!
true, also check the ground blocks on each front fender. One is located behind the air box and the other behind the battery. Just loosen and tighten them both a few times to make sure you have a good connection.
1 - 20 of 39 Posts
