1 - 14 of 14 Posts
Can anyone recommend a good headlight assembly replacement for 2010 colorado?
I am on my second set and around 2 years they fog/fade ect. Even after applying headlight restore!
"which didnt work"....
I fought the same battle and ended up just buying cheap assemblies from Amazon.
I replaced them about a year ago and they’re still leak free and look new.
I would say OEM is best but the cheap ones are pretty good for my needs.
Thats where i got the second set from. They are worse than the originals. This is a horrible flaw in these trucks! Both sets i put in leaked even after i sealed them lol
What did you seal them with? Did you use the flowable sealant? I did with decent luck. It flows down into the seams. I did mine off the truck so that I could position the assemblies so that the sealant would flow in the correct direction.
Its not just a problem with leaking it is also the lens itself. Its just a cheap design and materials. I used a clear silicone from Ace hardware in a small tube!
Discussion Starter #8
Did you run the sealant all the way around the assembly? I ordered this flowable sealant, i will give it a try!
Discussion Starter #10
I did notice that the replacement lights come from different countries, my last set came from Mexico and the newer set came from China!
I bought a new set off rock auto. Applied rtv between the plastic housing and lenses. Haven't had an issue yet.
I did the same as Sorcin, only I bought the flowable sealant from ORiellys. Actually, I have replaced every light housing (DRL, headlight, and taillight) on my 2010 with rock auto parts. Sealed each one on the bench first before install. All the factory originals failed on my truck because of moisture getting in behind the lens. Just poor quality and workmanship from the start.
We just polished up the original lights on my fathers 2010 today with 436,000 km. I did them a few years back with Mothers headlight restoration kit. This time we had to sand them staring with 240 grit paper and work our way up then used Meguires headlight restoration kit and lense sealant. They turned out really well. Took about 2-3 hours to do and left them installed in the truck.
CALI BOSS
When you get your new lights, install self-healing clear paint protection film on the lenses. They'll prevent the lenses from oxidizing which is the hazy coating you see
1 - 14 of 14 Posts
