Hello!
Heard and read allot of good stuff over the years on the 355 pages but have had trouble finding a definite answer on the following.
I'm taking the factory 5.3L engine, engine harness and ECU out of my wrecked 2010 4WD Colorado and putting it into my 2009 2.9L 4WD AR5 Colorado and plan to retain the manual transmission. I'd also like to have full functioning gauges and cruise if that's not to much to ask as this is my daily.
If I take the factory V8 engine harness and ECU from the 2010 V8 Coly and put it into the 2009 Coly, what tuning options should I look into in order to run the AR5 manual?
and what modification or bypassing is needed to the harness that runs to the original 4L60e?
Do I need to swap the v8 trucks fuse block as well?
Thanks in advance!
Thanks in advance!
