1 - 20 of 26 Posts
Started late in the day so didnt finish I hope to finish next friday or during the week right before woodward
the upper trailing arms and trailing arm mount braces will not be installed yet due to them being adjustable and I dont have the time to get them fined tuned yet so they will be done after woodward
Also the install was also done along with my brother
here are the pics
now the reason the car sits so high in the rear is some ******* put 3 inch spring perch lifts in
old spring and new spring (old seems beefier)
the upper and lower trailing arms (the mount braces are not pictured)
Fuckin Sweet! Those random hand gesture pics are always a laugh riot! You never know when you'll scroll across one and then BAM!!:lolsign:
i do what i can
Nice Geeds. Although just wondering how yours gonna dial in those adjustable upper links im not too sure on how that goes. I put similar ones on my SVO and never really messed with them lol.
Discussion Starter · #8 ·
i'm sure i'll figure it out my brother is going to check with some proturing guys
I guess it really just depends on how low its gonna be. I think your suppose to measure you pinion angle prior to removal and then once your lower you can reset the pinion angle back to stock.
Are those all urathane bushings? In the SVO/Mustang world they say its ok to install urethane bushings on the lower links but that the uppers should remain rubber so that the suspension can still flex around tuns or something. Maybe those proturing guys can chime in.
Discussion Starter · #10 ·
Well my brother finished most of the work except the uppers and braces but we will do those after woodward
for some reason the ass end sits real low compared to the front
so we may need to cut the perches down a bit and put them back in
some picks but i'll get better ones tomorrow
WTF? No full side shot? :dawg:
You're dissapointing me geeds!! :lol:
Looks good so far. :yup:
Discussion Starter · #12 ·
my brother had the car all day and I got home and it was in the garage you'll get day pics tomorrow
Discussion Starter · #15 ·
Day pics as promised
you can see the rear is kinda squating
rear gap
front gap
I'm taking the perches by a shop tomorrow to cut a inch out so I'll have a 2inch piece and a 1 inch piece and can swap them in and out
hopefulyl the car will sit better tomorrow
I don't know if it's true for all coil sprung cars, but I know on S10's if the springs aren't indexed in the pocket right it will keep it from settling all the way down. A local guy that just dropped his S10 had a hell of a time getting it to sit level because of that.
Discussion Starter · #17 ·
well a shop did the front so I'd hope they did it right
Discussion Starter · #19 ·
cut up the 3 inch spacers down to 2 inch spacers
and put them in
I'll put the shocks and wheels back on tomorrow and get pics of how it sits
Discussion Starter · #20 ·
got the car back on the ground
the car has a small rake and depending how the springs settles and how it looks with the new tires i may go another 1/2 inch to a inch to get it just right
but here you go pics of the car on level ground
1 - 20 of 26 Posts
