I went up 2 3/4" with the smaxx keys and I'm not sure how good my half shaft angles and all that are..
:yeahthat:Good luck with that. Shocks aren't going to give you any lift unless the shocks you have not are totally worthless. As in, the current shock can't support the weight of the bed. All shocks do is soften a ride.
Except for blocks - unless you want to lower it. LOL:yeahthat:
You need shackles, blocks, or an aal.
top of fender? never heard of anyone measuring from there... but whatever helps you get that extra inchLol I'm at 24 3/4 on STOCK KEYS from hub to top of fender and 40 1/4 from the ground. View attachment 134594 and a washer diff drop lol
Sent from crappy AutoGuide.com Free App
How are you measuring to determine the sag of the rear end?Yeah I have the two inch shackles on there but the rear is still sitting an inch lower so if new shocks don't help, I'll look into a 1" aal
I measured it hub to fender just like the front. I read on here that the stock height is 22" and with the shackles set at 2" I'm sitting at 23"How are you measuring to determine sag in the rear end?
Oh...well then it sounds like it's about as right as it needs to be then.Ok when I measured the rear from hub to fender I got 37" and the front is at 37 3/4" but I'll do the measurement under the truck like you stated
