1 - 9 of 9 Posts
I’m not sure how it happened but all the wiring from my transfer case was severed/pulled. Have a manual 2008 canyon with an 11 engine in it. I need to know where/how to find these to connect the wires.
Gas Jewellery Household hardware Metal Font
Motor vehicle Hood Automotive tire Automotive design Gas
Are you needing to know which wires those plugs go to or where you can get new plugs.
Sorry but I'm confused.
This is the best I could come up with. It may at least point you in the right direction.
Yazaki SWP connector
7123-1424-30
Sorry. I misread what you had wrote. I need new plugs to replace these.
Just an added bit of info. The OEM part numbers listed are for the bare connectors, just the plastic. If just the connector plastic is damaged, the existing wires can be removed from the connector and transferred. If the wiring is damaged and you go that route, you will need to order terminals and probably the plastic terminal locks. The Service part numbers listed are for connectors with pigtail leads attached. Those can just be spliced into existing harness leads.
Discussion Starter · #9 ·
Alright. So the consensus is in and the parts are no longer available. So I’m at a wreckers now trying to salvage them off a T/L. Fingers crossed…
1 - 9 of 9 Posts
