SO...From switching to floor shift auto..In theory and by my gm parts catalog it seems very simple. It looks like all you would need is shifter and a new cable for thr shifter. The NSBU switch is the sam on both trannys and would require very little work.
So I have ar q....What about the actuator for the shift lock control. The one that makes sure you have your foot on the brake to shift out of park? The'yre not even close to being the same on the two vehicles...would you have to buy an aftermnarket one...or keep your stock shifter in the colly, and constantly leave it in neutral? Or would it matter at all If you removed it? I know I wouldn't probably have a shifter light at all, but that doesn't matter.
H3 Shifter #15823064
H3 Cable#15087039
*Note* Any shifter would work, as long as it's cable operated.
H3 Cable#15087039
