1 - 18 of 18 Posts
So if I have done my research the right way I think I maybe able to turn my AWD into 4WD if I can unlock my front diff. I'm looking for the front axle tube plus actuator and then make my own harness with a switch inside the cab. Haven't come up with a plan to some how shut off the front drive shaft from spinning but I'm hope with the less drag on powering the front wheel I should be able to pick up 2 more MPG then sticking with my 13 MPG on the street.
GMpartshouse is putting me at $300+ and even then I'm not sure I got a hold of the parts I need. Anyone can help me out?
Have the axle tube. Just pay shipping. No actuator tho.
Discussion Starter · #14 ·
Sorry I never replied. Didn't see the thread. I'd say shipping would cost $20-$25 maybe.
Discussion Starter · #16 ·
That's fine with me also I need shaft inside the tube and if you still have the mount for it. Snap some photos if you wouldn't mind and let's get this show on the road!!! :salute:
The inside shaft is scared cause the bearing went bad. I gotta go get it from my storage unit.
1 - 18 of 18 Posts
