Hi all.
Sometimes I noticed my G80 did not lock up like it was supposed to. This always happened once in a while as long as I can remember. Sometimes when not locking, with one tire spinning, it would make a bit of a buzzing noise. But, mostly it worked just fine.
Spinning tires on wet roads today, I noticed I got some one tire fire.
My truck has 97k on it now, so I thought changing the fluid in the rear diff might do it some good. The fluid was pretty black as you would expect. The magnet had some sludge on it, and a few small metal shavings and flakes. Not great, but not particularly alarming.
After changing the fluid with synthetic 75W-90 (no friction modifier), I drove maybe 2km to a spot where I could flex and test. Grassy mound, at the edge of a gravel lot.
The diff would just not lock. Lifting right tire or left tire, forward or reverse, once one tire lost traction, I could not go further. The tire with traction would not kick in.
Finally, if I tried to to a burnout on the gravel, both tires would throw stones. Maybe a little odd. I would expect just one tire there too, but maybe both spun because traction was equal?
Maybe it was just being moody, and I should drive around, and try again some other time?
If I perform the test in this video, the tire tire does not kick back.
https://www.youtube.com/watch?v=xCwcr7Sj7Hw
I jacked it up to get both wheels off the ground. Turning one wheel slowly, the other wheels spins the opposite way. But, if I give it a rapid acceleration (as rapid as I can by hand) it does not kick back.
Anybody have any experience with this?
What should I do?
Anybody have similar experience? How did you resolve the issue?
Most online discussions seem to just be arguments about terminology, how the G80 is supposed to work, and other nonsense. Then somebody posts a picture of a grenaded one, and everyone says they suck.
Is a TruTrac the best / only option that is any better than stock? Can the G80 be repaired?
What should I do?
