I've been around here for the past few years and finally decided to make a build tread!
I'll have the rest of the pictures up when I get home tonight.
Here's where we start. In April 2011 I got my 2006 chevy Colorado z71 crew cab. It was pretty much bone stock except for an aftermarket Kenwood radio, and had 53k miles on the clock.
The first thing I did was do the dual hi/low mod and crank the tb's to level the truck out. After a couple months I got a flow master muffler and single rear exit tip installed. I got bored with the stock system and bought a kicker comp 8 and built a sealed box for it. The sub was powered by a cheap Kenwood 150 watt amp.
insert pic
I left it like this for a while then got bored with it. I bought a Kenwood 10" sub and a cheap infinity 2 channel amp. I also built another sealed box to house my new sub. Not long after I bought a power acoustik amp to match the sub little better. At this time I hooked up the infinity amp to my mids and highs. I left it like this for a while, then I got the mod bug again and plasti dipped the black surround on my grille and dipped my
bow tie white. I blew my Kenwood sub so I upgraded to a kicker cvr 10" and alpine mrp-m500, and moved my power acoustik to my mids and highs. My head unit started to act up so I purchased a new Kenwood bluetooth head unit. Christmas 2012 I upgraded my door speakers to Alpine sps 610 and 610c.
Around April 2013 I got bored with my system once again and built a new ported box for my cvr 10 and was very pleased with the way it sounded.
I went away to college in the fall so modding kind of stopped for a little while. During thanksgiving break i started working on a floor console that would fit a 1st gen full size ipad. progress went slow as I could only work on it when I was home for breaks.
Christmas 2013: my flow master muffler had a loose baffle that was rattling like crazy so I bought a new flow master cat back system from boosted5
I cut some DRL covers out on the water jet
I got some new rubber on the rado (bfg a/t)
this summer I plasti dipped my radio bezel and a/c vents.
I did the big 3 upgrade
insert pics
around this time I also bought a 17" led light bar
once again I kind of got bored with my sub setup so I bought a sundown sa8
I wanted to be able to fit 3 people in the back again so I made a box that would go under the seat. the box is 1.38 gross and 1.15 net volume tuned to 30hz.
I also put some sound deadener on the back wall and floor
September this year: I wasn't that satisfied with the way my first box sounded so I made a new one with a little different port.
October: i bought an iPad mini and started working on a dash.
[/IMG]
during this time I was trying to get my truck ready for SESM. I bought a sundown SAZ-1200d to power my SA8, ran 0gauge to the amps, bought 6 2600 farad, 2.7 volt ultracapacitors that wired in series have the ability to charge to 16.2 volts. These capacitors should handle about 90% of my amps that my sub amp is drawing.
insert pics
I also plasti dipped my wheels black
I got everything installed (0 guage, amp, caps, dash, etc the night before I left for SESM.
That's all for now. I still need to carpet the front and sides of the box and clean up wiring. Thanks to everyone on here for all of your knowledge and insight!
insert pic
insert pics
insert pics
