1 - 3 of 3 Posts
I have a 2004 GMC Canyon auto and my radio blew a fuse the other day and the cluster when out so I changed the fuse and the cluster still doesn’t work. I done looked at all the fuses under the hood and they wasn’t blown, if I click the stick on the cluster the miles come up but with the key on the cluster does nothing. Could anyone give me some advice.
Someone will always jump on here and say check your ground splices, do that it’s a good idea, also take the thing out spray rubbing alcohol in the plug and jack of the cluster let it dry plug it back in, hook battery back up because always disconnect that before you start messing with electronics. Hope it helps
Hey thanks for replying soon. I will try that and let you know what happeneds.
1 - 3 of 3 Posts
