1 - 12 of 12 Posts
Dont let the Nation die
ok, so my truck is in pieces changing out the driver side hub and CV. while at it doing diff seal and fluid change. but which oil to use??
before ya say it, i know its 75/90 synthitic. i got that. but which brand? every one swears by Amsoil. great, but no one carries it around here. every one has Moble1 and Royal Purple. even saw Lucas Oil gear oil. any one ever use their oil?
also, these oils have LSD bottles and bottles that are good for open and LSD diffs. jus get the oils for both, right?
I would think that you would be fine with either of those Manufactures. As for the type I am no help. Would think that you would need the one for both.
thats what i was thinking, as far as type. i use RP in the motors of the car and truck and never had an issue with it. and they are all about the same price, maybe a buck difference.
Mobil one all the way. Forget the shitty royal junk. Just good ole 75w90 synthetic from Mobil one is all you need front and rear.
Really Colorado Obsessed!
penzoil only cause my shop stocks it and amsoil but im a broke ass right now LOL
Discussion Starter #9
quess i should update this..
went with the Mobile 1. jus done front so far, since that was needed. rear and tcase maybe this next pay
252,000+ Miles
I stopped using Mobil1 in my diffs when they stopped making 75w-90 without LS additive.
I dropped in Amsoil Severe Gear 75w-90 Synthetic in the diffs and Amsoil Fully Synthetic Syncromesh in the transfer case.
Next up will be the tranny getting a complete fluid change over to Amsoil as well.
Discussion Starter #11
no one around here carries Amsoil. and cant be waiting for how ever long. i need my truck and had to get oil back into it. and this is just in the front diff now anyway
Can Mobile 1 75w90 LS be used? I just noticed the writing on the container says it includes limited slip friction modifier. Of course I already filled my front axle with it but haven't driven it yet. Should I drain it out and use something else?
1 - 12 of 12 Posts
