Yes that's correct, stock length for the 2wd 04-07 Canyons and 04-08 ColoradoThey arent longer are they? Just stock length for the 2wd trucks?
CorrectIt should be for the rear line right before the T hard lines.
Well that's good to know, thanksThey should fit the 09+ brakes too; form looking at my 09 calipers they mount the same way
So the length would maybe be the only difference? i was thinking maybe a fitting would be different since its different calipers :shrug:Based on what 1BADI5 said, I'd say yes, but I think the safer route would be to check the stock specs on the 09+ brake lines to see their length and so long as these are the same or longer you should be gtg
In that case i might be interested, ill do so more research and make sure. thanksNo, per 1BADI5 (a few posts up) he looked at it and the mounting on the calipers is the same=
