21 - 24 of 24 Posts
My dad was probably down in your neighborhood at the end of WW2 during operation Magic Carpet, liberating POWs.
Magic Carpet link
Back to the truck, my thinking was there's probably an aviation machinist around who could rebuild your existing head, and avoid the shipping cost and headache.
Discussion Starter · #23 ·
Hi All
Update
The parts arrived 2 weeks ago.....sea freight.... and we should be starting the work this weekend
I'll post up what we find
Regards
Jacko
Discussion Starter · #24 ·
Hi All
So after 7 months and a few frustrations I have the Colorado back, fixed and running nicely.
The parts took forever to get to me via New Zealand and then my first mechanic wasn't able to get to do the job .....long story.
I found another guy who did the work and am more than happy how it all worked out.
He pulled out the motor took off the head and found the intake valve spring retainer had failed causing the valve to stick open and jam inside the guide.
Long story short the head was replaced along with the list of parts below which include a few "while you are in there" parts which were replaced.
Parts used
Off E Bay
GM 2.9L DOHC Cylinder Head Assembly # (124294700067) $750.95
From Rock auto
ENGINE-TECH S95524-STD Piston Ring Set $ 27.79
ENGINE-TECH BC150JSTD Crankshaft Main Bearing $ 106.79
ENGINE-TECH BB151JSTD Connecting Rod Bearing $ 35.79
AC DELCO AC 213-3519 Camshaft Position Sensor 2 $ 41.78
GATES Z O VVS145 VVT Solenoid / Actuator $ 26.40
GM GENUINE CT1107 Clutch Release Bearing $ 71.79
ENGINE-TECH TS0195A Timing Set $121.79
ENGINE-TECH C178K1 Engine Kit Gasket Set $104.79
ENGINE-TECH EK322 Oil Pump Repair Kit $ 89.79
MAHLE GS33416 Cylinder Head Bolt $ 53.79
MAHLE JV5039 Timing Cover Gasket $ 22.79
MELLING 377S Oil Pump Pickup Tube $ 44.79
US MOTOR WORKS MCK1048 Water Pump & Fan Clutch Assembly $ 59.79
Total $ 1558.82
These prices don't include freight and the duty at this end (around 30% of the total)
Labor was approx. $ 1951 at today's exchange rate but that included the fitting of a new air conditioner compressor and condenser and a few other minor parts
There are many threads about the problems with our trucks but not many "end stories" so I hope this helps someone down the track as to what to expect to pay
and what parts you'll need to rectify this common problem..... the dreaded bad head / valve
Let me know if any one wants any other info
Regards
Jacko
21 - 24 of 24 Posts
