*99-06 Chevrolet 1500 4.5" BDS lift spindles (have to ream out the tie rod mount hole a bit to accept the H3 outer tie rod)
*99-06 Chevrolet 1500 hubs, brake calipers, pads and rotors
*Michigan Metal Works Hummer H3 tubular upper control arms (modified to use 99-06 Chevrolet 1500 upper ball joint style, and made with the non-adjustable bushings instead of heim joints, so they can handle the harsh winters here in Alberta)**I wanted the tubular style instead of plate for more room when I eventually try to stuff in coilovers
*Canyon/Colorado 4" Skyjacker lift crossmember, diff drop, and front driveshaft spacer (I'll likely get a custom front driveshaft made in the future)
*RealLift Hummer H3 4" lift torsion bar relocators (just ordered the last set they'll likely ever build for a H3)
*99-06 Chevrolet 1500 4" lift Bilstein front and rear shocks
*Homemade shackles in the rear with Canyon/Colorado Skyjacker 4"lift leaf pack, with extra helper spring
