1 - 8 of 8 Posts
Batman
I used to have an Undercover hard plastic one. It was great other than it hanging over the rails. It was amazingly watertight, and you could stand on it if needed. I just didn't like the plastic dimpled look of it.
Now I currently have a Checkmate and it looks better, but it doesn't do to great at holding the water out. Does great holding it in, my Bedrug is kinda musty now.
If I had it to do over again I would find a way to smooth and paint the Undercover.
Sent from AutoGuide.com App
Man am I glad you don't keep a sharper eye on craigslist! lol I just picked up a checkmate for 150 bucks from a guy in Winter Springs yesterday.
jk man jk hahahaha, thanks for finding it and letting me know.
My Undercover is very watertight. The overhang isn't an issue nor is the textured finish. It's truly one of the best things I've bought for the truck. I can live w/the appearance if the function is outstanding, which it is. it's very well-designed, strong enough to walk on, and you can remove it easily-enough if you have to transport something tall. I can remove mine by myself, I use a couple of tiedowns to make it easier to do that, I loop them around it from side to side and use 'em as a lifting strap. If you had a garage you could just use a light block & tackle to lift it a bit and drive out from under it. You could do the same thing from any handy tree if you needed! Or, two people can easily do it in 2-3 minutes. Remove the front tab split rings, disconnect the struts' (no tools needed) balljoint attachment points, and lift the topper from each side.
Discussion Starter · #8 ·
Justin, only shared cause it didn't fit mine. haha, glad to see you were able to grab it.
Thanks for all the input guys. got some more ones to look into. the other one i have been eyeing is the lazerlite, maybe after next tax refund, lol.
1 - 8 of 8 Posts
